Setting Airbag Suspension to high...
  • Setting Airbag Suspension to high...
    Hi Guys,
    i was wondering if it was possible to set the airbag suspension to high so it stays high? Even if i turn off the auto leveling, once i start driving it automatically comes back to normal position.
    Mainly for when going 4wding for that extra clearance.
    It drops back down once you reach a certain speed, can't recall exactly what speed but it's pretty low.
      The auto levelling system resets to normal once you attain a speed of (I think) 15 or 20 kph. I dont believe you can change this. I only use the high position if I require a little extra clearance over an obstacle (tree etc..) and then I put it back down to normal immediately. There have been a couple of occurrences where people have experienced their airbags popping while negotiating lets say, "Undulating terrain" with their airbags fully extended. ("Bad")
        From memory:
        From high to normal height, it will drop down once you reach 50km/h.
        From low to normal, it will raise itself once you reach 30km/h.
