By years end, I may well be in a position to lift the Prado. I'm not sure I want to go the full 2 inch lift - extra wear (to CV boots etc), total height issues, CoG problems...but would be happy to be convinced otherwise.
As an FYI - ARB Bull Bar only with lights at the moment. Fridge and Second Battery in Rear, also probably approximately 100kg of extra load in the rear when camping/touring etc. Current Front height - 755-765mm depending on the day. Current Rear height (unloaded) ~780
Does anyone have a 30mm lift on their 150?
Is it what you thought?
Should you have chosen 50mm instead?
What combination of shocks/springs did you go with?
How much did it set you back?
Do you have any photos, especially comparing with the stock setup?
