2" lift install
  • 2" lift install
    Is there a how to thread to install.
    My search doesn't show anything more than 5 threads
    Here ya go;
    http://www.pradopoint.com/showthread...ade-for-Grande
    Best
    Mark
      Cheers mate
        I've install the struts but have noticed the springs rub hard on the uca
          That's not right, make sure everything it sitting right on the seats and everything is bolted up correctly
          [LEFT]Silver 150 Facelift
            Lots of brands have too much travel & do that.
            IMO it's crap, poor engineered products.
            What do you have?
              Bilsteins and King springs hd
                What's the full extension spec on the bilsteins you have?
                It's too much.
                The greater the c/v angle the greater your chance of damaging a c/v too.
                  What's the new suspension height? What accessory weights have you got over the front?
                    it measures about 60mm after install.
                    one side looks like it will rub at full extension
                    front has steel bar, steel winch and dual batterys.
                    King Springs
                    Coil Springs
                    KTFR-101HD
                    Heavy Duty Coil Spring (TOP END MACHINED) (sold in pairs)
                    0
                    King Springs
                    Coil Springs
                    KTRR-102HD
                    0
                    Bilstein
                    Shock Absorber
                    BE5A712
                    46mm Monotube Gas
                    0
                    Tough Dog
                    Strut Tops
                    TOY-1084
                    Rubber Strut Tops. (sold in pairs)
                    0
                    Bilstein
                    Shock Absorber
                    24-238830
                    46mm Monotube Gas
                    0
                    thats the kit
                      The new strut tops may explain how you are getting some UCA contact with the coil.
                        could be whats happening. what causes this will it dissapear once they settle
                          IS this what happens?
                          I am trying to figure out a solution for this.
                          My setup is similar to yours
                          1X PAIR FRONT KING SPRING COILS: KTFR-101 HD
                          1X PAIR REAR KING SPRINGS COILS: KTRR-102 HD
                          1X PAIR FRONT BILSTEIN FRONT STRUTS: BE5-A712
                          1X PAIR REAR BILSTEIN REAR SHOCKS: BE5-A713
                          Will need to change the split boots but need a solutions otherwise the boot will split again.
                          2010 Silver Prado 150 Series : Blackvue Camera: GME UHF Radio: TG150: ARB Deluxe winch bar: ARB Bash plate: T-Max Winch: Narva HID lights:
                            What is your ride height??
                            What is your full droop measurement??
                            Something isn't right for that to be sitting like that.
                              That picture is taken when the Prato is on the hoist.
                              The current front and back ride is 840. It been like that after 3 years installed. Since the it been to the Simpson.
                              Wondering if the spring have been install upside down? The model no: printed on the spring is reading upside down.
