Originally posted by Orrsom
View Post
Kakadu suspension upgrade - any successes?
The front is 793mm drivers side and 800mm passenger side.Originally posted by amts View PostWhat is the current suspension height and droop measurements?
The rear and Neutral height is 830mm drivers side and 820mm passenger side.
High setting
870mm Drivers rear and 855mm passenger side. This is measured from the bottom of the rim to the underside of the wheel arch through the centre of the rim. The front remains the same.
I've been told to adjust the KDSS on the prado it's slightly different to the 200series. Instead of jacking the body higher on the low side with the bleed valves open, you actually jack the high sided axel into the wheel arch with the valves open then tighten. I'm told you can get it within 5mm or so. Otherwise Toyota can attach the pump and add more fluid and reset the level at my next service.? Will give the jack a go first.
Different service to this one: http://www.pradopoint.com/showthread...ght=caloffroad
Anything ever come from this Zerosecta?
Zero ripped the lot outOriginally posted by Piggy View PostDifferent service to this one: http://www.pradopoint.com/showthread...ght=caloffroad
http://www.pradopoint.com/showthread...-adjuster-kind
Hi winstonwolf , in Brisbane you could call zordo or pm him. He is a forum member . I believe Aussie Andy has installed the cal offroad gear with king springs so you could pm him to ask about pros & cons as he's very knowledgeable & helpful
Cheers Matt
Sent from my SM-J110F using Tapatalk2008 120 GX D4D with a few extras
Rig build here
Can anyone tell me how I trick the rear airbags on the 150 kakadu please ? any photos ?
Sent from my SM-G925I using Tapatalk
- 1 like
Thanks Amts, I got 8mm spacers in their. Gave me 20mm lift. What's everyone doing ?
How many mm of spacers are guys putting in to achieve desired lift ?
