KAKADU Air Suspension to Coil Spring Standard Height Conversion
  • KAKADU Air Suspension to Coil Spring Standard Height Conversion
    Hi guys. I own a Toyota Prado 150 VXL which is Kakadu in Australia. I find the ride a bit on the stiff side and have decided to convert it to coil springs. I know there are lots of topics about this already but mostly on 2 inch lift. I am looking at changing it to standard height. Has anyone tried it? Also, how did you get rid of the error indicator on the instrument cluster? Hope anyone has an idea on how to go about it. Thanks
    Your profile says that you are in the Philippines. Otherwise I have Kakadu specific coils to suit, that is a tad softer and just a small lift from standard height.
      Yes i am located in the Philippines but i want it to be stock height. There are lots of shops here offering 2 inch lifts but i want it to be stock height. Also, once i convert the rear airbag to coil springs, i dont know how to disable the warning lights on the instrument cluster.
