ironman suspension
  • ironman suspension
    is there anyone else out there running iron man suspension
    I have a 2012 v6 prado gxl with no bulbar or batteries ect
    I have the foam cell struts and performance springs all round
    front
    toyo65b coils and 24750fe strut
    I have measured from bottom of rim to guard
    front
    825mm ride height this ==== around a 75mm to 80mm lift
    850mm car jacked up
    gives me 25mm of droop =====minimum should be 60mm
    rear
    840mm ride height
    945mm car jacked up
    gives me 105 of droop
    just wanting to know if any other prado guys are getting similar measurments with iron man lift kits ?
    cheers let me know what u got
    burntoast
    Lurker
    Is there a spacer ring fitted under the coil seat on the front struts? Can you post some photos?
      Hey,
      Can anyone with these struts post up photos so we can see the correct coil seat orientation.
      Also can someone get a ruler on the strut and double check the closed and open lengths.
      Your droop and ride height figures would be good to know as well!
      Thanks!
      Best
      Mark
          We have just come back from our Darling River Run Trip and I had the LHS Front Strut Top Nut/Stud Thread strip and I had to have both struts replaced in Lightning Ridge. The only struts the mechanic had in stock was Ironman (I was running Lovells). I obviously had the mechanic fit the Ironman struts so we could continue our trip and they performed faultlessly for the rest of the trip and gave a good ride, but I did forget to ask the mechanic whether they we suited for a 2" lift, like I had or standard height..... I'll have a look tomorrow and take some photos showing how the coils sit, but does anyone know the model numbers of what a 2" Ironman strut is? Just a bit concerned that they may have installed a strut for a std height Prado.....
              24750fe strut is the 45mm lift struts for the 150 I'm interested to know your droop
