Suspension Kakadu
    Re: Suspension Kakadu
    Ken mine are similar to yours.
    How did you go with the bar fitting?
    2011TD Kakadu
      Sambo150
      Have picked up the car this afternnon and really happy with the look. The trouble and stife thinks its a bit square!!! Liked the plastic look
      The front has gone down a bit and the bum up. I think that you do notice it as it seems that you can see over the bonnet!!! Also the steering is a bit heavier due to the extra weight on the front. It was very light before the bar
      Measurements are
      Before After
      LF 880mm 875
      RF 880mm 870
      LR 905mm 925
      RR 910mm 925
      Hope this helps. I would still like to get a lift. Or at least upgrade the front suspension
      Ken
      2010 150 D4D Kakadu, Graphite, Toyota tow bar, Tint, Mats, Headlight Protectors, Redarc dual battery and Brake controller,Sahara Bar,Safari Snorkel,Icom440,OME suspension,Steinbauer module,Genesis HID lights.
        You could raise the front 40mm then when off road raise the rear 40mm on the air bags for a total 40mm lift ? Unfortunately anything over 40 or 50kph will keep lowering the back causing car to be nose up...doh.... how do we disable that default setting ?
        Hopefully time will see the Kakadu able to be lifted as I'm ready to get mine done.
        2010 Kakadu with all the usual stuff.... Build up thread below
          Originally posted by KJA
          Sambo150
          Measurements are
          Before After
          LF 880mm 875
          RF 880mm 870
          LR 905mm 925
          RR 910mm 925
          Ken
          Thanks mate. PM sent.
          2011TD Kakadu
            I have now done 1000km with the new bar and remeasured the distance of the guard from the floor
            Before After
            LF 880 870
            RF 880 870
            LR 905 920
            RR 910 920
            Either the suspension has settled or my eyes are crook. I hopeit is the former as I would have expected the measurements as listed
            I expect the LR measurement before could have been 910.
            Ken
              Bump.
              Any news on Kakadu suspension upgrade?
              My rig build up.
              [url]http://www.pradopoint.com/showthread.php?23037-KC-s-Prado-150-LC5-European-specs-build-up-thread[/url]
