Originally posted by bazzle
View Post
Suspension Measurements
Bit the bullet and had Coastal 4x4 fit the spacers for me. I'm away at the moment but have seen pictures and the Prado finally looks level. Will post measurements when I get home but looking at the pics it appears to have raised the nose approximately the 30mm required to make the side steps level with the ground. Hopefully fitting the spacers should mean that I retain the stock droop (what there is of it) as the shock can still move down, rather than pushing the shock further down in its stroke.Kev,
Originally posted by Kev7762 View PostBit the bullet and had Coastal 4x4 fit the spacers for me. I'm away at the moment but have seen pictures and the Prado finally looks level. Will post measurements when I get home but looking at the pics it appears to have raised the nose approximately the 30mm required to make the side steps level with the ground. Hopefully fitting the spacers should mean that I retain the stock droop (what there is of it) as the shock can still move down, rather than pushing the shock further down in its stroke.
was that with the 10mm or 20mm spacers??[I]cheers..... Rob (macca)[/I]
[B][I][COLOR=Green]Car-2: 1993 Suzuki Vitara 4Dr (modified for Playing) [/COLOR][COLOR=#ff0000]Now Retired[/COLOR][COLOR=Green]
[/COLOR][/I][/B]
25mm spacers
New measurements
FR 775mm
FL 778mm
RR 818mm
RL 808mm
After a week of driving around, wheel align tomorrow, looking at figures, might need to adjust airbag pressures, all appears to be good now.Kev,
Kev any before and after pix ? So the 25mm spacer gave 30mm of lift ?[CENTER][B][U]Matt
[/CENTER]
[SIZE=2]
[/SIZE][CENTER][SIZE=2]
[/SIZE][/CENTER]
I did take some, but haven't got around to posting them yet.Originally posted by Matt - mr4x4 View PostKev any before and after pix ? So the 25mm spacer gave 30mm of lift ?
Before was 734/ 740,
after 775/ 778
so almost 40mm with the 25mm spacers, coastals told me they use the 10mm to get an extra 25mm for the 3" lift they do on hiluxes.Kev,
