BF Goodrich Vs Bridgestone
  • BF Goodrich Vs Bridgestone
    Hi Guys..
    Any body knows about the comparison between Bridgestone Dueler H-L and the BFG T/A KO 275/65R17 .. I am sure the Bridgestone is not noisy which is i like it. any idea ?
    Haven't used the Briddgestone, but the BFG are very quite for what they are.
    [B]Steve[/B]
      Hello Alnassar,
      You seem to be comparing apples and oranges, your bridgestone H L is a highway tyre and the BFG is not. If you compare the Bridgestone Dueller LT 694 with the BFG you would be comparing apples with apples.
      The lt694 is very quiet and out performed the bfg in 4x4 action magazines a/t comparison. I have had both and prefer the lt694 although there is nothing wrong with the bfg either.
      regards
      Ross
        BFG A/T, Mickey Tompson STZ, Cooper LTZ or Dueller 694. You cant really go wrong with any of those tyres, very similar in performance on and off road.
        [size=1]2011 GXL D4D Auto | ARB Deluxe winch bar | Bilstein/Ridepro platinum lift | MT ATZ P3's | Dick Cepek Torque rims | Airtec snorkel | Lightforce Genesis 55w HID | GME UHF | 55w HID high beam | Rhino Rack bars & Cage | ISI extreme rack | Dual Optima Batteries | Milford MXV-70 cargo barrier | ARB onboard air | Prodigy P3 | Drawers & Black widow fridge slide | Waeco CF-50 | Kaymar rear bracket and LED light | EscapeGear seat covers | Sandgrabbas and more...[/size]
          Thank you guys.. the quiet tire its really important to me, i use it mostly in highway.
          But also i do some off-Roading let say 1 in a month . and i do like the BFG TA pattern .. but afraid about noisy in a long highways..
          What do u think ?
            Alnassar, not sure what Prado you've got but the BFG is very quite on our 150, even on the really coarse roads up north. I assume the Bridgestone is the same, but can't comment.
            [B]Steve[/B]
              Mine is 150 .. I hope its quite same as bridgeston .
              Sent from my GT-I9100 using Tapatalk
                Hey i just did 2500k's on Yokohama Geolanders and very happy with them. These don't get talked about much but they are definately a 'quiet achiever'
                  Stick with your Grandtreks then, they are a good tire you just need to run the right pressure. Plenty of people have done long trips on the GT's and when rotated properly some very good mileage as well.
                    Depends on what you want from your tyres - my criteria is mileage, wet and dry grip, low noise, resistance to chipping on gravel/rocks etc. You will find personal opinions and recommendations in many discussions on this topic in this and other outdoor, camping, and 4x4 forums. I run D694LTs because they perform well to my criteria. But I am sure the others mentioned in this thread perform OK as well.
                    TG.
                      I have had 694's in a 65 profile and now BFG's in 70 profile. The Bridgies had a noise like a diff whine between 60 and 70kmh, but definitely ride smoother because they seem more supple/flexy. The BFG's are quieter, harsher, and harder to balance. However, the sidewalls don't bag anywhere near as much at the same pressure and give me much more confidence on dodgy roads. Traction on bitumen seems the same, but BFG a bit better off road I think. It's the perceived durability of the BFG that I like. Also have greater tread depth. Used them for many years on lots of dodgy road surfaces with no problems.
                        I've had BFG A/T on 3 prado 120's and never had a problem with them. They do get a little bit noisy if under pressure on the highway but if at the right pressure there is no problem. Very good tyres if you are going on rocky/puncture prone roads.
                          Thank you guys... i appreciate ur comments its really helpful .
                          by the way.. what is the best air pressure for on road ( normal use ) for the BFG's ?
                            Jack.. in which pressure u get noisy ? and what is the perfect air pressure for the BFG in highway ?
                              My UK LC4 (VX in Aus) is fitted with OEM Bridgestone 840 HT Duellers ..... coped well last year on ice and snow - no idea how they would cope on Australian terrain though....
