Wheel alignment question - When to do it after a lift
  • Wheel alignment question - When to do it after a lift
    So i've had a 2inch Koni lift installed for a week now, and thinking a wheel alignment is on the cards. However, i still have a winch to install in a couple of weeks.
    Is a 'true wheel alignment' based on weight of the car, or does it not matter.
    Just tossing up on if it should be done now, or if i should wait a couple of weeks (<1000kms in travel)
    Alignment is based on the weight which determines the ride height. Best to do it after the winch goes in.
      Did you install the lift or was it a workshop? It should have been done at the same time as part of the installation. Tyres can wear badly very quickly if the alignment is not right.
      Travelling Panelbeater
