To all of you out there who have not removed your spare or are getting a service.
We have had our Prado since February 2010 and for us has been a wonderful transition from a Jeep to Toyota. During this time we have never had to make use of the spare wheel and as the vehicle is primarily a family car I don't get too much time to tinker and do the things I want to do like remove the wheel cover or mod the reverse camera. I had only had the wheel cover off once when we had to use a bike carrier.
Anyhow to cut to the chase I had to remove the spare wheel and plastic backing of the cover to allow access to the rear window as my wife has decided to advertise her personal training business on the back of the Prado, (I will have to order another Pradopoint sticker and attach to the side rear window). As I believed this was a relatively simple task to complete I didn't worry too much about getting all the tools out. I set about taking the wheel cover off then removed the wheel wrench to loosen the wheel nuts, the two solid nuts loosened but were extremely tight. Now for the lock nut, so I got the key and took the locking cover off to reveal the nut. Then as the book says to use the wheel wrench I placed this all the way down till it seated inside the wrench and tried to loosen the nut, it was tight so I continued to apply pressure using the wheel wrench and just my hands and arms, it felt like it was turning ever so slightly. I took the wrench off to see my progress and what I saw was a twisted lock nut that had been transformed into a warped version of what it previously was, as depicted below...This amazed me as I only used the supplied tyre wrench.
As it was now 9.00pm and my wife had the car booked in for a 8.00am appointment for the rear sticker what was I to do, I thought about going to a mates place with a full workshop but due to the time I decided that I would go into Toyota first thing in the morning to get it sorted as they should be able to get it off with an air wrench.
Morning arrived and off I went to Toyota, great workshop, but obviously when the vehicle came new the spare lock nut was put on way too tight as it took two hours of trying to loosen the nut resulted in failing to loosen the nut. The mechanics had to oxy the nut off and replace it.
So for everyone out there who hasn't had their spare off or just picked their Prado off I urge you to get Toyota to remove the spare or check and loosen the nuts on the spare at your next service or if you are a long way from your service have it checked because I can only imagine the trouble this would have caused us had we acually had a flat tyre and required the spare in a remote area or even on the highway.
Paul
Paul
