Shower install in a 95
  • Shower install in a 95
    Hi PPers,
    I was just wondering if anyone has put a shower system under the bonnet of their 95 Series?
    I'm interested to know where you mounted the Heat Exchanger? I'm heading to Cape York in August and thinking of putting one in.
    Dave.
    90 series prado with lots of stuff.
    We have a Twine. I put the heat exchanger is on the right side of the engine bay (left as you look from front). The pump is in the back right corner (back left as you look at it).
    Michael and Kelly
      I mounted my heat exchanger inside the bull bar and the water pump is ontop of the guard near the firewall up away from any water.Thats in a 120 but same principle for any model
        Thanks guys for the quick reply and the ideas. Most of the heat transfers seem to be approximately the same size so I just need to pick a brand and get into the installation. Do the kits come with all the fitting brackets?
          Twine did, but I purchased 12 years ago.
          Michael and Kelly
            I made my own and it is going left side of engine bay as you look at it.
            we heading to the cape in august too, should be good trip
              Thanks Coatesy,
              We will be in Cairns on the 1st of August and then heading up to Cape Trib on the 3rd and then up to Cape Melville and then up to Weipa on the 9th then up to the Telegraph on the 11th and in Bamaga/Cape area on the 15th. We may even cross paths.
              What did you make your system out of?
