Recovery point for 90 series with factory alloy bar
  • Recovery point for 90 series with factory alloy bar
    I was contacted by a fellow Adelaide PP member to look at recovery points for his 90 series fitted with Toyota alloy bar.
    This is the bar in question
    This is the bullbar mounting bracket which bolts onto the chassis. It has an integral tie down point which is far too low to be used as a recovery point as it will bend. The front face of the bracket blocks any way of mounting recovery hooks.
    This is the concept of a new "recovery point". It requires drilling 2 holes into the side of the bullbar bracket and is positioned as high as possible to reduce the leverage from the distance to the chassis. There will be a next revision to improve it a bit more.
    Does anyone else need these points as it will be cheaper if more are manufactured at the same time.
    Yes , Yes , Yes , finally something !!!
    Cheers , Michael
    yes its a prado with a motor , wheels , doors and things ...
      I've got an Ironman bullbar and need front recovery points. Would yours suit?
        I sense someone is mildly interested :P
        It depends what your bullbar mounting bracket looks like.
          I won't be back in Adelaide til April I can send you photos if that would help
            OK you can send it to amtsprado at gmail dot com.
              Cheers Andrew, I'll get some pics to you by Sunday
                [ATTACH=CONFIG]8621[/ATTACH]
                Don't forget the weakest link is the rating for the recovery point. I would make the mk:11 version out of steel plate. Not sure that paper clips are rated either. Ken.
                Didn't see the op date.
                ken2m
                Ken
                3.4 GXL man 1997 petrol / gas, BFG mud tyres 265 75 16, front and rear camera, Jaycar 6300Lm LED 6.5" D/L * 2, 15W LED reversing/work light, diff breathers, 42mm lift, Rear Anderson plug, Dash cam, and way too much recovery gear for one vehicle to carry around. No more HID headlamps. No more Narva D/L.
                  Did these ever go into production???
                  96 3.4 GXL, 2" lift, Poly airs in rear, 32" BFG muddies, Lightforce 170's HID's, TJM rack, Awning, Twine on board shower, GME uhf, Dual batteries & monitor, Storage system, ARB fridge, LED rear lighting, Safari snorkel, Brown Davis bash plate, Ironman winch bar, Runva 11xp winch, Roadsafe recovery points, ARB compressor, Tyre dog monitor, AJ's sliders, Hema hn6. The to do list is getting shorter.
