ARB bar mounting
  • ARB bar mounting
    Hey guys,
    Just bought a used ARB bar for the RZJ90, bought it from a good friend and its in pristine condition.
    I have a doubt about how to mount it. I have absolutely all the hardware, but he said something about having to drill extra holes for a couple of bolts. Is this true or does the bar bolt on to the existing holes on the frame??
    Anything I should take into consideration when mounting the bar??
    Thank you for any support!
    Luis
    Hi Luis
    normally should be without drilling new holes
    at my bumber I didi not drill new ones
    please check the screws for mounting at the frame !!! , some are with fine windings !!!!!!!!! ( I hope my english is good enough to explain this )Click image for larger version
Name:	Kopie (2) von SV Frontbumper_025.JPG
      Thank you Cruisergerd!! The car's looking good with the new bar all mounted up, I need to wire the indicators and the spotlights but overall extremely happy.
      I thought it was weird that it needed drilling of the frame, managed to put it on myself and its solidly bolted. I need to buy some grade 8 galvanized bolts for added safety.
      Thank you so much for your reply, i will be posting an updated picture on the "show off your 90" thread
      Luis
        hi
        looks very good !!!
