Multi Info Meter
  • Multi Info Meter
    G'day All,
    I have recently purchased a 2002 Prado VX, and beside loving the new ride following an "upgrade" from a tiny WRX, I was wondering if anyone can shed some light on the Multi Info Meter. I am trying to hunt one of these down for retro fitting, and I haven't been able to come across one, nor any info on the net. Can these be bought ANYWHERE?? And if so, can they be fitted to said vehicle?? We are looking forward to heading bush, and being a total novice, are hoping this will guide us as beginers. Any ideas and advice would be greatly appreciated.
    Ed
    Ed
    as far as Im aware they were only fitted on the imported models, not positive though.
    If they all work as good as ours I wouldnt bother, temp ussaly out at lest 10'C, altametere works off air pressure and is always wrong, compass requires resetting all the time.
    If there is a way of removing it and all its sensors your welcome to it. than I could buy a dashmat for it.
    Glenn
    Glenn
      Glenn,
      You couldn't perhaps describe how exactly to reset the compass? The MID had "Mode", "up-arrow" and "down-arrow" buttons - holding up and down for a few seconds and then pressing up causes the compass to flash which I assume is the resetting part. I've driven circular trenches in the dirt but still the compass only seems to show southerly directions no matter which way the car faces. Any help would be most appreciated.
      Chris
        Hi there,
        From memory ( I did this once and it worked), bring your compass to set mode (I think it the pressing the left button then the right), drive your vehicle and make a complete 360 degree turn then press the left button.
        The manual also suggested driving backward and forward 4 times each at 90 degrees angle to each other.
        No harm in trying...good luck
          Hello Ed,
          I bought mine on ebay from a seller in Mongolia. He had it shipped to me and it arrived promptly in Chile. I paid less than US $80 for it, plus a $20 cable I bought from Toyota Japan through my local Toyota dealer.
          I connected it, tested it and it worked, I plan to install it soon, for which i'll be making a custom mounting bracket since my unit came without one.
          You'll also need the termometer's sensor used by the info unit to display the outside temperature.
          '97 RZJ90 GX 3RZ-FE 2.7
            Hello all , i am a proud owner of LC 90 year 2000 and i have to say i love my car .
            I have a small problem with the Multi Info Meter suddenly the light of the monitors went out i try to unmount it but i didnt manage to open it.
            What should i do ?
            [url="http://www.braters.gr"]http://www.braters.gr[/url]
            [url="http://www.toyota4x4.gr"]www.toyota4x4.gr[/url]
            Proud Owner of LC 90
              I'm looking for one also, didn't find anything on the web yet...?
                can you explain me please how you unmount it so i can check the cables.
                I cant find in any manual
                  hi all
                  could you tell me please, how I can search the multi info meter, I try to find out since january, but, on the net, I could'nt
                  Roberto
                  UIO-EC
                  Roberto
                  UIO-EC
                    i found a great manual , i will post it tommorow
                      http://pagesperso-orange.fr/adherence_4 ... 9_elec.htm
                      merry Christmas everyone
                        Here is a pic of mine....
                        Frank
                        2008 Prado VX
                        285/70/17 Maxxis Bighorn M/T
                        TJM Equipped Bullbar and Suspension
                        HIDs
                        Factory Digital Inclinometer/Compass
                          Re: Multi Info Meter
                          I'll have one for sale shortly, please PM me if interested
                            ok i manage to unmount the Multi Info Meter but all the cables are in place and i have an electrician to check it i need a new one.i am going to have a net search before asking toyota because i think it's expensive..
                              Seems like a very long time to be bothering about this gismo ..... the compass and altimeter needs resettting all the time .... the only real useful feature is the temperature reading but that is usually off by 2 to 4 degrees .... I am considering ripping mine off ... let me know if you need it badly after your search ....
                              1) Land Cruiser 90 V6 3.400cc, 50th Anniversary edition, TRD supercharger, unichip, automatic, 5d, 2" suspension lift, cold air intake, straight muffler, 265/75/16 mud tires, wife, kids, dunes and wadis
                              2) Land Cruiser 90 V6 3.400cc, manual, 5d, 2" suspension lift, cold air intake, 265/75/16 mud tires, wife, kids, mud & snow
