UHF CB Install Location
  • UHF CB Install Location
    Hey Guys,
    I was told by a local reputable communications company that it was impossible to install a larger size 2 way radio in a 90 series Prado.
    Well, didn't I prove them wrong! I thought I would share it with you for your inspiration!
    http://www.clh.com.au/photos/radio.jpg
    http://www.clh.com.au/photos/radio2.jpg
    90 Series Prado VX Grande
    Steel Deluxe Winch Bar, 2" HD Suspension Lift, MAXTRAX, ARB Roof Rack, Outback Drawers, Sand Grabbers, Side Steps, DVD in dash and Headrests, JVC Sub Woofer, Lightforce XGT's, Garmin GPS, WAECO CF40 Fridge/Freezer, Tait T2020 UHF CB / Scanner
    Looks good! Phillips FM90?
    When do the new speakers go in? :twisted: :lol:
      Tait T2020 100ch 450 - 520Mhz, I mounted the speaker under the centre console just behind the 4wd Shift. The speaker is loud enough and is well hidden.
        Sorry, the new speakers in the pic silly me .. They went in a day after the photo was taken hehe
          Noice... that's where I've got my slimline TX3200... good to see a full DIN fits there nicely as well
          Cheers, Leon
          Optix Photographix
            Just started looking at installing my GME radio like you guys have done but stopped when i found the ABS and airbag modules. After hearing horror stories of airbags deploying when using a CB in other vehicles, was wondering if anyone has had any probs with the prado??
            The pics in the first post show that airbags are installed so i pressume not, but thought id check anyway 8)
            '98 Grande V6 - ARB Sahara bar, IPF HID spotties, ARB compressor, GME UHF, OME Sport suspension, 265/75 MT ATZ 4 Ribs, steel rock sliders, Safari snorkel, Tigerz11 winch, rear ARB locker, Rhino platform rack.
              I asked about 3 installers if they've had any issues with this as I heard that as well. None of them could recall any issues that they knew of and said she'll be right mate
              I then had some issues with the ABS on my Prado and mentioned to the Toyota guy... 'could the placement of the UHF be effecting the ABS?' Nah, was his answer so I mentioned the rumors regards the ABS and Airbags and his answer was again... 'nah, never had any problems with installing them there'.
              So, who knows... but nothings happened yet and I've seen heaps of units installed in that spot.... that said though
              Cheers, Leon
              Optix Photographix
                Thanks for the info Snaga, will install mine there as it seems right at home in the available space
                  Yep I have my Uniden in the same spot.... :lol:
                  Richard
                  2011 GXL TD Auto Prado Silver
                    I will fix it there too an will post a few pictures later!You all have so excellent ideas!
                    And Snaga I count on your toyota mechanic! :wink:
                    the german fellows
                    [url="http://www.landcruiserfreunde.de"]http://www.landcruiserfreunde.de[/url]
                    my car becoming adult:
                    [url="http://www.landcruiserfreunde.org/viewtopic.php?t=134"]http://www.landcruiserfreunde.org/viewtopic.php?t=134[/url]
                      Do you mean 'wouldn't count' ...?? neither would I
                      I take everything they say with a grain of salt :roll: I have a good mate who is a mechanic who I ask any advise of.
                      Cheers, Leon
                      Optix Photographix
                        Re: UHF CB Install Location
                        Originally posted by cheilig
                        Hey Guys,
                        Hi cheilig, hi snaga
                        Cheilig, you are a lucky guy,that your radio fits there, I tried to fix my there,too, after having all parts.
                        It
                        It's a Stabo xm 3003 with DIN dimensions, wich means 48x180x164mm (hightxwidexdepth).What a desaster! On the back side of this bracket there is a seam wich indicates that a DIN-frame fits.
                        And it does more or less.
                        The power I took from the socket in the lower dashboard.
                        The wiring for The antenna was also done, after connecting everything the radio didn't fit into the frame because there is a part of a retainer you have to remove, without function, so don't worry.(look for the white arrows)
                        I hate to use a metal saw in my car, but I did it!
                        Originally posted by snaga
                        ...good to see a full DIN fits there nicely as well
                        It doesn't fit there! Sorry, behind this retainer there is not enogh space, so that the result is this. So I stopped when I had to remove the retainer of the airbag module! This seemed to be a bit too hot! I'm a wimp!
                        There is missing space in the wide and in the depth! So consider well if you want to fix your radio in this spot using a DIN (Deutsche Industrie Norm=german industry standard) sized radio and you also must have a surgeon's tools . In Germany it dos not fit! I will tell you the end of the story when the murder is out.
                        In this case smaller seems to be better or easier!
                        the german fellows
                          Bugger smiller :cry:
                          Is it the depth that stops it fitting :?:
                          Cheers, Leon
                          Optix Photographix
                            Hi Leon!
                            yes and no, after 7-8 cm it's not wide enough on the right side. But when the radio is too big it has to become smaller. Still unsure, what to use, hammer or saw :wink:
                            the german fellows
                              :lol: :lol:
                              Cheers, Leon
                              Optix Photographix
