Hi, I enquired at some local places about getting a hitch receiver fitted to my 90 series. I already have an LPG tank fitted. I've chosen to go with Hayman Reese as I have heard that the genuine Toyota gooseneck is smaller in diameter? :?
Has anyone fitted a towbar/hitch receiver to a 90 series that already has LPG fitted?
I was told by some places that they won't do the fitting and that Hayman Reese have discontinued making towbars/hitch receivers for Prado's fitted with gas due to design/safety issues. Effectively, bad luck no towbar for you! :cry:
Other places have said that they need to see the car. If there is no impediment to accessing the installation points they are happy to do it (not sure what this means re the above story I've been told :? ) and if there is an access issue they need to get the car to an auto gas place, have the gas disconnected and drop out the tank, fit the towbar then refit the tank and reconnect the gas. This seems like a big job and will raise the $$$ of the overall cost. Anyone been through similar?
I mainly want the hitch receiver so I have a rear recovery point but might do some towing at some stage.
Any advice/war stories would be appreciated. Thanks.
