With a couple of threads on where to locate UHF radios I thought I'd take a quick pic and stick it up here.
I didn't do the install myself... but,
:arrow: The back of the coin pocket was cut out so the GME TX3200 would fit neatly in the recess.
:arrow: Power was taken from a cig lighter so only on when acc. are on.
:arrow: Aerial cable runs through a small grommet in the passenger side firewall and the aerial is mounted to the first bolt forward of the bonnet hinges by a RH bracket on the passenger side. It was put on the opposite side to the radio aerial as apparently they can effect each other and sometimes cause damage to the UHF radio.
:arrow: Mic bracket is attached with the supplied screws into the plastic radio surrounds and is accessible by driver or passenger very easily.
I have found no need for an external speaker as the built in one can be heard quite clearly in most environments.
Hope it helps...
Hope it helps...
