2 inch Body Lift
  • 2 inch Body Lift
    If i wanted to get a 2 inch body lift fitted to my vehicle do i need to extend anything eg, brake lines etc? I already have a 2 inch coil lift but am thinking about a body lift also.
    If the body lift can go in without doing any mods then that would be gold, but just want confirm with other members before i go ahead with the purchase.
    96 GXL Prado 3.4L with 50mm HD front coils and MD rear coils with poly airbags, Bilstein shocks, 265/75R16 Federal couragia MT's, black sunnies, GME TX4600 UHF, ZCG 6.6db antenna, Narva 175 driving lights, 20" and 38" LED light bars, roof rack, Safari snorkel, ARB bar, Redback extractors and a custom 2 1/2" exhaust.
    Here is glen_ep's 1.5" body lift.
    http://www.pradopoint.com/showthread...l=1#post304879
      Brake lines, radiator/fan alignment, transmission selectors, etc would all need modifactions I would think...
        Thanks lads, that answers my questions. Glen has done his vehicle up very well, looks and performs great.
          Thanks AB
          The essential mods are:
          - 8x body blocks (in two different sizes)
          - Radiator drop to line up with engine
          - Steering extension
          - Rear cargo bump stops (above the chassis, behind the rear wheels)
          Other mods to consider:
          - 4x4 selector; mine is okay, it just touches the plastic interior, but with 2" BL you'll probably need to do something about it)
          - Transmission selector; my auto just needed adjustment from underneath. It's not actually a mod, just a very easy adjustment of a bolt/slider. The gear selection is a little stiffer after BL. I don't know if anything is required for manuals.
          - Rear bumper impact bar (mounts to both body and chassis)
          - Bull bar lift (or bumper)
          - Positive wiring harness (cable is a bit short on v6, it might make it though)
          - Handbrake cable extension and rear guide bracket (I've fitted an aftermarket bracket from USA).
          - Sub tank inlet hose needs adjustment or possibly even extension on larger lifts.
          - Main tank bash plate could be raised to gain clearance.
          A couple notes:
          - Unhook the heater hose at top/rear of engine bay before lifting
          - Air piping after the filter will bend
          - No flexible brake lines need to be extended for the Body lift, but the steel lines will need to be stretched (at the front, where they're coiled up)
          - I don't have ABS or traction control so have no idea if that complicates the matter.
          - It's not legal to body lift a vehicle with Air Bags
          If you'd like me to elaborate on anything above, just ask.
          Look through my build up thread for some photos.
          glen_ep
          Addicted PP Member
          Last edited by glen_ep; 13-01-2012, 11:44 AM. Reason: Cargo bump stops are an essential mod IMO
            i Suggest a 1.5 " body lift. as it is much easier to do on these vehicles, i did mine myself, including the making of all the parts, and the radiator is easily relocated as there are more hole 1.5 inches down in the body work already, just a little push and shove to get it in them and shifter lengths are fine in a manual. if you want i can do up some drawings of the parts i made up so you can take them to a mchine shop and get them made up, might be cheaper than buying a kit. and i can say that other than that it is an easy lift to do with just a socket set and a jack.
            1997 3.4 V6 Rv. mods; 1 1/2 inch bodylift, 285/75/R16 cooper STTs, 16x8 sunraysia style black steel rims '0' offset, 2 inch heavy duty springs, bilstein shocks (80 series rear), GME remote mounted UHF.
              Awesome thanks for the tips guys. I'll be in contact when I think about it more seriously. I think the better option will be 1.5" since most other members have used it and know how to fit them etc.
