Was doing a service on my car and adjusting the rear left door striker was supposed to be the simplest job of the day.
I backed off the bolts a little too fast, and now the nuts that hold these bolts have fallen into the door. You can see the part im talking about below:
there is no clear rear access, as it is between two panels; and im not sure how far down the channel goes (ie is it possible for the nuts to have moved down to the lowest channel?)
What i have done so far is get a retractable snake magnet, but i just cant seem to find it through the holes pictured. not to mention im not entirely sure how id attach the bolts if i ever did find them
Ive also pulled off the bottom trim, but i cant see the nuts in there
Has anyone else had experience with this? at the moment ive got some rope holding my door shut
