Driving home from work today, and noticed the car pulled to the left badly when I hit the brakes, then the next time i hit the brakes, it pulled up straight..... but.... there was a loud grinding noise from the left front, when I got home, I pulled off the front left wheel, and low and behold, the pad had thown the lining off, now I have a destroyed disc as it has worn 1/2 way through the disc, now I have to buy new discs and pads, looks like no work for me tomorrow...lol
Damn It !!!
Originally posted by samo View Postthats a bugger croozza, hope you get it sorted and cheaply lol. cheers samo97 VX Grande, with front & rear air lockers, ARB Sahara winch bar with tigers 11 winch, 2" EFS lift, 265/75/16 Achilles Desert hawk XMT, and more.
Originally posted by MUMSRIG View PostAhh Bugger... That sucks. I have a 15% worn set of Bendix Pads I replaced today if your desperate...
Just goes to show how something can go wrong if your not paying attention97 VX Grande, with front & rear air lockers, ARB Sahara winch bar with tigers 11 winch, 2" EFS lift, 265/75/16 Achilles Desert hawk XMT, and more.
Originally posted by croozza View PostAll good thanks mate, I will get it all done tomorrow. I might even put slotted rotors on depending on the price difference, but going on last time when I put slotted ones on my old 80 series, it was only $30 difference in the price between the two.
Just goes to show how something can go wrong if your not paying attention2010 Kakadu with all the usual stuff.... Build up thread below
Originally posted by KAKADAZ View PostGood excuse to get the slotted rotors mate.2011 150 GXL D4D Auto White, ARB Deluxe Bar, Windcheatah roof rack, Warn 9000 winch, IPF Spotties, Mounted ARB Compressor, GME TX3540, Codan 9323 with 9350 Auto Tune Antenna, Kaymar rear spacer & HF mount, OME Sport Shocks & Springs, Safari Snorkel, 5T Rated recovery points, Exhaust Jack, BFG AT tyres, Maxtrax, Scangauge.
[/CENTER]
All fixed now, didnt go for the slotted, mainly because they had to get them in, but I ended up with DBA rotors, and QFM (Qld Friction Materials) pads (to try, and report back on how they perform), reason being is the Bendix pads are tapered at the leading and trailing edges to stop squeel, but that means you have less pad area on the rotor, so the pads are working harder, the QFM ones dont, so there is more pad on the rotor, giving better brake performance (in theory), all up with the total cost was $25097 VX Grande, with front & rear air lockers, ARB Sahara winch bar with tigers 11 winch, 2" EFS lift, 265/75/16 Achilles Desert hawk XMT, and more.
Originally posted by Anth120playdo View PostHey mate, pads are are rotors are cheap, new brakes all good!
What brand pads did you have in?97 VX Grande, with front & rear air lockers, ARB Sahara winch bar with tigers 11 winch, 2" EFS lift, 265/75/16 Achilles Desert hawk XMT, and more.
Originally posted by Talktheroo View PostCrooza, you probably going to hate me saying this. You need to check your Pads and rotors regularly. It's off with the wheels every couple of months under normal conditions and clean out the area with brake cleaner and water. By doing this, it will actually extend the life of the pads and the rotors. No build up of pad dust. The brake fluid should be changed out every 12 months at least.
Wait a minute, I haven't checked mine for a while, I better add it to the list.
Yes, it's easy to overlook, that's why a written schedule is so good. Wait a minute, I haven't got one of those either, hmmm.....
The hippocrite Roo.
I have found that these new pads (QFM) are a very nice pad, they give a very nice feel from the start (before they have bedded in), but now that they have bedded in, they are awesome, the Prado has never stopped so well.97 VX Grande, with front & rear air lockers, ARB Sahara winch bar with tigers 11 winch, 2" EFS lift, 265/75/16 Achilles Desert hawk XMT, and more.
Originally posted by Talktheroo View PostTRW is another good brand too, Croozza.The old Lucas pads, 1323s. QFM make taxis brake pads pacific to the taxis industry, and they last thirty percent longer than anything else. Australian company and Australian made too. Where did you get your QFMs from Croozza? I can still buy these from Yellow Cabs at Woolloongabba. How much did you pay for the pads?
The Roo.97 VX Grande, with front & rear air lockers, ARB Sahara winch bar with tigers 11 winch, 2" EFS lift, 265/75/16 Achilles Desert hawk XMT, and more.
