2nd post here guys - hoping to help someone out thats still working on their 90s (and seeking some additional advice)
My problem: The notoriously bad Prado 90 handbrake began failing to hold my Prado in place on slight inclines, forcing me to keep it in gear and putting all the pressure on my 1st gear - not ideal. I decided to have a go at fixing it myself. I was unable to find a full post on breaking down the assembly for cleaning/adjusting and reassembling so I'm making an attempt to do that with this post. If I missed a previous post let me know and ill add this there instead.
Pictures with step-by-step (to the best of my ability) here - http://imgur.com/a/SIeHg
I am STILL experiencing issues with the handbrake. Before I went at it myself, I took it to a mechanic to get an opinion and I was told the brake shoes were worn down to the metal/indicator. You can see in the pics above this is definitely not the case. Im at a loss for what else to do and looking for some advice from those much more experienced than me.
When I parked on a hill and engaged the handbrake, the tension was holding better than before, but still rolling forward/backwards. I decided to apply more pressure to the leaver (past 6 clicks) and felt a deep "thud" almost like tension was releasing somewhere inside the assembly. My best guess is the star wheel was too tight and the additional pressure caused it to fail, but I'm not sure. Have any of you experienced this before?
The last thing I will try, which I didn't have time to do over the weekend, is to adjust the bell crank on the backing plate. if anyone has some advice on this area please let me know.
Thanks for reading and looking forward to your comments!
