Now that my winch is installed, my front end has dropped a bit. It's now 55 mm over stock (805 mm total). I also installed a diff drop.
Having testing this on the motorway, I'm getting mild vibration between 55 and 62 mph, under heavy acceleration. It becomes light vibration under light acceleration. Outside of this range, it seems to be fine.
Should I be worried?
I'd like to keep this amount of lift. But, it would be good to try to track down and perhaps eliminate the vibration. Initially, I wasn't sure if it was the CV joints or the U joint at the input to the differential. So, I removed to diff drop. That made things worse. Vibration range increased to 50 to 65 mph and became more severe. I could even feel faint vibration when decelerating.
So, the diff drop is definitely helping, and I'll be putting that back on, next weekend. But, because of the way the diff gets angled, it effectively drops the centre of the diff only by 1/2 an inch. So, that would make it equivalent to a 1.6 inch lifted CV angle.
So, I think the problem is definitely in the CVs. But, I'm not sure which one. With the diff drop installed, I can't feel the vibration in the steering wheel. So, my first suspicion would be the inner CVs. But, I'm not really sure. I'm not an auto mechanic!
Ideas?
Can the diff be dropped further? Perhaps, in the rear mounting? Could this be due to aging CVs? Would re-packing or replacing the CVs improve things? Are there better CVs that could be installed? What about installing manual hubs, effectively turning the LC into part-time 4WD? I'm sure that would make the vibration go away.
BlueRock
2001 LC90 (Colorado) D-4D, lifted and ready to winch
Ideas?
BlueRock
