I have a noise coming from under to the rear of my car ( I think) it sounds like i have something stuck in my tyre but a bit deeper sound. It isnt my tyres as it is happening with my old set and my new Mickey T's. It happens when you are low to mid revs accelerating. Stops if your put your foot on the clutch and when you take your foot off the accelerator. Please help if any one else has experienced this. Hopefully its not a too big job. Thanks Mass
Annoying Clicking noise
Sounds like it is something making the noise only when it is loaded up, so it could be a uni joint, or bearing. Which one it is, is the question. You will have to see if you can get any abnormal movement in the driveline.97 VX Grande, with front & rear air lockers, ARB Sahara winch bar with tigers 11 winch, 2" EFS lift, 265/75/16 Achilles Desert hawk XMT, and more.
Hmm sounds like a bit of work thanks for your time in answering my question hopefully by this i can start driving a quiet car =) except for the hum from my new Mickeys =).1999 Prado Snowy 265/75/16 Mickey T's ATZ 4RIB, Uniden 80 channel CB, 2" EFS with PolyAirs, PP Rear table, JVC Bluetooth deck.
Just heard back from my mechanic crown wheel and pinion are knackered. Couple of teeth chewed out.... So second handy on its way... Wow i wish i had some more cash to get a locker put in at the same time..... Off to sweet talk the minister of finance =O1999 Prado Snowy 265/75/16 Mickey T's ATZ 4RIB, Uniden 80 channel CB, 2" EFS with PolyAirs, PP Rear table, JVC Bluetooth deck.
I started reading this thread, thinking I have the same problem. I got it after a challenging track on the weekend.
Just got it back from the mechanic who said that the diff is fine, no evidence of metal in the oil etc. He thinks it's possibly a split in part of the cardon/uni joint near the transfer case. Mine is an auto so it's not the clutch. I too was hoping I'd need a new diff centre, so I started getting quotes for a locker. Now I have no immediate justification. Still I might go ahead anywayDavid
2013 FJ Cruiser
265/75r17 Cooper ST Maxx, Rear locker/A-Trac/Crawl
Losi Comp Crawler for the really rough stuff
The 90 series Diff club club has a new member!
Its a pity that both front an rear crown wheels didn't go. You would have had justification for new diff ratios and twin lockers![B]Declan[/B]: [SIZE=1]1997 GXL 4.5 Auto 80 series on [B][COLOR="#FF0000"]LPG[/COLOR][/B], ARB bullbar, 2" OME lift, 32" MTZ, GME UHF, rear ARB locker, Kaymar spare wheel carrier[/SIZE]
Originally posted by BirdMan View PostHaha It turns out it was the same problem. 2 teeth chipped off crown wheel.
[ATTACH=CONFIG]3194[/ATTACH]
The mechanic discovered it while putting a locker in. Now I have to wait a few days while they source a new crown wheel and pinion
I just changed my diff ratios so have heaps of diff parts lying around, including crown/pinions...glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Originally posted by BirdMan View PostThanks Glen, I'll be round to pick them up tomorrow.
You've been a great helpglen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Just had new clutch fitted to my 90 series at Toyota and final cost was ~$1600 including clutch and left parking light :-(2000 Prado 95 Series 3.4 v6 GXL, OME Nitro Charger Sport, 2" lift, ARB Deluxe Bar, Warn WD9000, Safari Snorkel, GME TX4500, ARB Air Lockers, Hayman Reece Towbar, Ruffnuts seat covers, Sandgrabba mats
Have you tried greasing your uni's. A dry uni can make quite a clicking sound and get worse the more milews you travel with it.----------------------------------------------------------------
[url="http://4x4galore.com"]http://4x4galore.com[/url]
[email="[email protected]"][email protected][/email]
98 Prado V6, 2" ToughDog suspension,custom front sway bar, Detriot TruTrac front diff, Unichip, custom sliders,ARB bullbar, 265/75x16 Goodyear Wrangler MTR
Originally posted by glen_ep View PostNo worries mate. During the process did you get a price for genuine parts? I just checked toyodiy.com and it's listed as $1,122 !! (so they'd probably cost ~$1,400, ouch!!)David
2013 FJ Cruiser
I finally got her back today. Glen's 2nd hand crown wheel and my pinion (yes I know you shouldn't mix) have been lashed well so there is no diff whine. Runs like a new one now, well it pretty much is all new ...David
2013 FJ Cruiser
