Hi all. After a recent PP trip the grease nipple for the slip joint on the rear prop shaft has been torn off by the sub tank bash plate.
It has left its make on the sub tank too. I am just really surprise that this would even happen with my suspension setup.
I would expect this to happen if I had a custom panhard rod but as none of the rear linkages have been changed the rear suspension geometry should be largely the same as that of a none lifted Prado. The only difference I can think of is that the down travel of the OME shocks is longer than the Toyota shocks.
If this is the case, I suspect all 90 series owners running long travel shocks could be at risk of loosing the grease nipple the same way.
I'm not sure if I need to replace the whole prop shaft or if the grease nipple can be replaced.
If I am reading the parts reference correctly it looks like the grease nipple is availible as a separate part (96451‑00600) but I guess it all comes down to how easily the broken grease nipple can be removed.
http://www.toyodiy.com/parts/p_G_199...KQ_3701.2.html
Any thoughts from you mechanical gurus? croozza?
