About 3 months ago the radiator on my 2001 TX (auto turbodiesel) failed suddenly at the housing for one of the ATF cooling lines, resulting in a near total loss of coolant and partial loss of ATF. At first I thought I had got away with just replacing the radiator, but soon afterwards I noticed an excessive amount of coolant was being transferred into the overflow tank and not syphoned back on cooling. A TK test confirmed that combustion gases were entering the radiator. Apparently the pre-combustion chambers in the 1KZ-TE motor are prone to cracking. So now I have a new aftermarket head and a new radiator, water pump and thermostat. I've been told that a head replacement often accelerates deterioration of the drive train and can lead to other expensive engine problems. I'm reluctant to quit the vehicle because it only has 160,000km on the clock, had been exceptionally reliable until the radiator failure incident and has around $12,000 worth of aftermarket upgrades and accessories that I would get next to nothing for. I should mention that I use the Prado to tow a 2.1 tonne off-road caravan into the back of beyond, so mechanical reliability is a big issue. Can't afford a new Prado and used ones with the D4D motor are still very pricey. Any advice?
GrahamS
GrahamS
