transaxle codes A02B
    They are codes from Prados and Colorado 90 series in Europe and Japan
    No Soarers or other TMC vehicles were harmed in the making of that table.
    Maybe the Aus market codes were different?
    I don't know but that table is true for European vehicles.
    KZJ90 1-KZTE GL
      Bounder, we shall see. I ordered the part for a LSD type dif. I know if it is the right one if I open the dif.
      When I search the Internet after starting this thread I allready found an (older) Amerikaan forum who also says it is a LSD dif... I will know for sure when it is opened.
      Got a call from the Toyota importer in the Nerherland, they also could not tell me what sort of diff it is.....
        Originally posted by BorS View Post
        Dear prado lovers,
        I need help about the transaxle code of my VZJ95. I would like to know if someone can tell me the if the code A02B is a open or a LSD dif.
        This code is on the Vin plate below the vin nr. Could any one tell me this.
        I searched the internet but could not find 1 answer, some pages say it is an open dif, some say it is LSD.
        Thank you, Bor
        I would have at a guess from the vehicles I have looked at it is a 4.3 open,
        It seems to be the code is :
        01 = 4.1
        02 = 4.3
        A = LSD
        B = Open Diff
        the usage seems to follow this pattern:
        4.1 in Diesel, 4.3 in Petrol, due to torque/rpm range etc.
        LSD in all unless fitted with the VSC, TCS, then it is Open diffs and the ABS does all the magic
        I hope this helps, only my findings so far, I did prefer the old system to work it out
          01 = 4.1
          02 = 4.3
          A = LSD
          B = Open Diff
          so from this table, are u able to use Toyota supra centres in our diffs? so i currently have a01b (Non LSD 4.1), can i install the supra A01B diff which is also 4.1 how ever is LSD? or are the diff centres designed different
          95 series 02 VX
          Current mods: 265/75r16 MT 4 ribs, arb winch bar, arb roof basket, cargo cage, rear airbags, Clarion nx700e head unit, snorkel, rear DVD players
          To do mods: k&n air filter, 2" lift, tinted windows, duel battery system
            so, can we confirm that A02B trans/axle code is 4.3 no LSD?
            11/06 kdj120 gx wide body auto
