Hi
Just came back from a weekend offroad trip, drice about 310 kilometers each way, plus two days of offroading.
After driving a about an hour, the transmission started acting a bit weard. about 70-90 km/h, on some hills. Shifts more or less normally, but it seemed that the lockup is a bit sharper, and also on some hills it's almost like it can't decide if to let go of the lockup at about 85 km/h, or to go out of overdrive as well.
This passed, and it worked fine all weekend driving offroad.
On the way home, it started again, usually when driving on some hills, when it shifts down or out of overdrive, I get a "clunck" in the driveline, and it got worse as I drove on. I could provoce this by letting go of the throttle and when going again, I got this "clunck" again. Almost like too much play somewhere. I made it home, and I have not been able to look more at it tonight, other than getting under right after I came home and check if something was leaking or hot.
Rear diff was about body temperature, transfer box and front diff was so hot that I could put my hand on it but not keep it there for very long, I would say maybe 60-80 degrees Celcius.
The transfer box I expected to be hot as it is directly bolted to the automatoc transmission, which should be about 80 degrees, but I wonder if the front diff should be this hot? It is tucked away close to the engine sump, but still...
Any ideas about whats troubleling my driveline? What to start looking for?
It is a 1997 3,0 td, auto as you probably guessed.
I was listening for unnormal noises but my Cooper STT's makes it difficult.
Any input or good advise wanted
Thank you very much.
