Prado - advice on locating possible bearing issue
  • Prado - advice on locating possible bearing issue
    Hello,
    After converting to Land Cruisers from landrovers I have hit a problem.
    I've a few ideas:
    1) central drive shaft bearing
    2) wheel bearing
    3) another bearing in the axel area
    Car is a Prando 2001 3.4L petrol GXL Auto.
    When driving, I am getting a consistent revolving rumbling noise - it is coming from the center of the car.
    Noise is definitely related to a rotating part so expecting it to be a bearing.
    the frequency of the noise increases as the car speeds up - in time with the rate of revolution of the drive shaft/wheels turning
    Its an auto, which i am unfamiliar with, but when I put it in neutral when driving, the noise still exists. hinting at a bearing within the axle however the noise is not louder at either side so perhaps not a wheel bearing?
    I am currently in australia, without access to tools otherwise I would take things apart and investigate. So I would like to pin point the issue before I find a local garage where I can rent their unit for half a day to fix the issue.
    Any advice would be really great,
    Thank you very much
    Jasper Mowatt
    0431118900
