Auto Trans Acting Weird
  • Auto Trans Acting Weird
    Hi there,
    just wondering if anyone has had trouble with autos in this model before. Mine seems to be fine on the highway untill i give it a boot full and it then seems to not be able to follow how hard i am accelerating as it just changes gears very fast all the way till last gear.
    It then fixes itself by when you come to a dead stop and it is fine again.
    It will also do the same thing if you are crawling in traffic.
    Can anyone help me diagnose the problem
    2002 Vx Prado 95 series. 5vz-fe Motor. 2" Lift. Ironman Springs, Constant load in back. Dura Shock Shocks all round. Yokohama AT-S 265/75 R 16. Rhino rack bars and rhino rack cage. Long handle shovel holder. Tent pole Pipe. Awning. 240 Blitz lightforce lights. TJM premium Alloy Bar. Custom Rear Light. Uniden 400sx UHF. In dash dvd touch screen. Splits In front speakers. Custom rear draws. Canvas Seat covers all round. Custom dual battery cradle. Projecta dual battery system. 40l engel fridge.
    Re: Auto Trans Acting Weird
    Oh and also when it is acting weird i know it, cause it does like a really sloppy shift through one of the gears like it can't pick, and then it actually sticks in gear so to speak. You can be cruising down the highway and back off and it acts like a manual, it holds the gear and pulls the car up, it doesn't let the revs die down and coast along like an auto usually does.
      ok, start off with the simple stuff, Have you checked the transmission fluid level? if it's low it can do all kinds of crazy stuff.
      next thing what does the fluid look like? is it nice and pink/red or has it turned brown and burnt or even blackish. it might be due for a filter and oil change/flush.
      depending on km's and when it was done last, i'd be getting the transmission serviced and flushed anyway. if that doesn't work then it's time to take it to a specialist (not a toyota dealer, I said SPECIALIST). you're probably best off taking it there for a service anyway.
      good luck.
        Hey
        i actually forgot to mention, i just changed the trans fluid cause thats what i thought it was, and let me tell you, to get that level right is so hard and i thought i had it good.
        My mechanic mate checked the levels out for me when he done a check over on it a couple of weeks ago.
        I was going to take it somewhere in the new year to get it checked out properly cause i had a commodore do this similar thing to me once and it was the solenoids in the gearbox were gone.
          Hi,
          just as a minor point, have you used the correct tranny fluid? for example the fords now use a different mix of tranny oil than the older style dextron2. if you use the old style, the new 4 speed ford autos play up badly. just a thought, not trying to be smart !!
          i spent 16 years in sales of transimssions parts, and as the saying goes, if i have a penny for every time......, well lets say i have a new prado in the garage ! easy mistakes can happen, and spare parts guys can make mistakes
          regards Tony
          2000 Prado GLX, manual, 3.4ltr with LPG conversion, dual batteries, bullbar, driving lights, 3 handbrakes (wife and 2 kids)
            Hey
            yeah i have the gregorys hand book and it said that you use dexron 3, so that is what i have used.
            But it was playing up before i changed the oil cause it was due for the change, although it wasn't playin up as much
            all your help is appreciated guys
            thanks
              Sounds electrical ? do these autos have a transmission computer ? I would get Toyota to plug in a diagnostic scanning tool on it
                Hey mate, have you checked your error codes?
                I had exactly the same issue, checking the ECU, it showed a Throttle Position Sensor fault.
                Swapping it out fixed the issue.
                Always thought the auto gearbox had a bit of a sloppy shift, it is so much better with the new TPS, must have be marginally screwed for some time.
                  It may be a little late, but check the air flow sensor. I had a dirty M.A.F on a series 2 Discovery which was causing the gearbox to change irregularly. I think I first read about something similar on LCOOL.
                    Hey mate, ive got a 1999, auto. i had the same problem except mine would shuddler and felt like she was going to fall apart. Turned out she needed a major service. there is a place where i live called G&T auto. wasnt to bad on pricing. havent had any trouble since
                    1999 Toyota Prado Landcruiser GXL - White
                    3.4 V6, Auto
                    The toys are -
                    Blue Narva ultima 225's
                    2 inch lift, gas front and foam cell in the rear - Ironman
                    Safari Snorkle
                    Uniden UHF
                    Keyless entry. More to come
