Clutch Not Engaging
  • Clutch Not Engaging
    Hi All,
    My Prado has been having some clutch issues over the last few days. When I press the clutch peddle in the clutch doesn't release and the clutch peddle doesn't return properly. When the clutch peddle returns its really slow too. Ive bleed the clutch and cleaned out the hydraulic piping with clutch fluid. I also wound the foot peddle to the clutch nearly out so I would get maximum movement with the clutch but I still cant put it into gear. Can anyone help please??
    clutch pressure plate?
      how can I check the clutch plate?
        gear box out.
        so maybe if you live near a mechanic if you can still drive it take it in, id say they would diagnose it and even quote you how much it will cost.
