Re: Oils
This is a common occurence with the front diff, the capacity is a lot less than the back diff and being hard to get to means it gets ignored or not done. I just had to replace mine after bending the pinion shaft after the bearing collapsed from lack of oil after the passenger side seal failed and lst the oil out.
Where do you get the aftermarket plugs from? Someone that does online sales preferably.
