90 Series Parker Removal
  • 90 Series Parker Removal
    Hi I have recently tried changing my parker globes and when putting the new ones in the globe popped out and fell into the surround. I have tried probing a few things in there to get it out to no avail. How do i remove the actual surround for the indicator/parker light? I have found one screw on top but do not want to break anything. Thanks.
    1999 Prado Snowy 265/75/16 Mickey T's ATZ 4RIB, Uniden 80 channel CB, 2" EFS with PolyAirs, PP Rear table, JVC Bluetooth deck.
    Re: 90 Series Parker Removal
    Describing the removal is probably harder than actually doing it. Remove the screw on the top and then pull the indicator forward away from the body. There is a tab on the indicator body that fits into a slot lower down. You may have to give it a little tap to get it out. Be careful you dont damage any of the wiring loom by pulling too hard. Like I said, its harder to decribe than it is to remove.
      Hi - hope this helps...(and not too late!)
      There's a screw on top ,remove that.
      Slide your hand down behind the indicator/park light unit and gently push the unit foward, in the direction you would drive, straight ahead. It might help if you wiggle it slightly up and down at the same time from the other side with your other hand.
      (There's a plastic peg on the unit that slips into a rubber grommet holding it in place. The peg is horizontal, facing rearwards, in line with the vehicle).
      Hope that makes sense!
      PS it's s 5watt bulb (park)
      Prado 95, not quite original!
