Where to find blinker/parker signal factory loom/plug?
  • Where to find blinker/parker signal factory loom/plug?
    Hi Guys,
    I recently installed a Ironman bullbar to my T/D 90 series and I'm having trouble finding the factory plug which has both the blinker and park light signal on it.
    I tried testing the wires (on a factory plug behind the headlight) which were the same colour as the ones going to the blinker on the passenger side but wasn't getting anything with the blinkers going.
    I figured if there was a factory bullbar option with blinkers/parkers in them then there would have to be a factory unused plug lying around which it would plug into?
    Thoughts?
    Tones.
    Mine was a 3 pin white nylon thing.
    Its a branch from the main loom which runs across the underneath front roughly under the radiator. Its about 60cm directly behind where the indicators would be.
    I got rid of them anyway as they aren't waterproof.
    Fitted these instead - http://www.ebay.com.au/itm/Kit-3-Pin...item1c2b18ec71
    Malcom
    Prado 95 TX turbo diesel
    LC100 GXL turbo diesel
