power window mods 90 series
  • power window mods 90 series
    Hi everyone,was wondering if anyone knows how to wire up the power windows so they operate with ignition turned off? i run lpg and to turn ignition back on so you can close a window injects gas into inlet manifold,very annoying.hopefully someone knows how,i cant even find the relay at this stage, but im told its behind the drivers side kick panel.Cheers dave.
    This describes how to modify your power windows so that they can operate without the keys in the ignition.
    Required Tools
    -Philips Screwdriver
    - 10mm socket & driver (suits both lower dash panel & integration rely)
    - Side-cutters (for cutting the wire sheath)
    - 2x Male Tab crimp 6.4mm connectors (Dick Smith P/N H-3228 pkt of 10 $2.24)
    - 1x short length DC wire cable (Dick Smith P/N W-2025 rated @ 50V/17A $1.25/m) split & use one wire
    - Crimp tool (pliers &/or soldering iron)
    - First step is to remove the lower dash panel on the drivers side.
    - Remove the screws holding the petrol cap release and the bonnet release.
    - Push the handles back and maneuver then out of the panel.
    - Remove the screw (on the left side) and the bolt (on the right side), and gently remove the lower panel.
    - Undo the connectors for the sub fuel tank gauge and the dash illumination control.
    You have to remove a portion of the vent duct to the drivers side to fully access the Integration Relay
    - On the left side of the drivers foot well firmly pull down on the duct.
    - On the right side, slide your hand up until you feel the duct joint. Pull firmly down on the lower half. Remove the duct.
    Integration Relay- with Vent duct still in place
    You must unbolt the Integration Relay to access the Power Window relay.
    -Remove the lower and upper bolt on the Integration Relay
    -Move the Integration relay towards yourself to disengage the retaining clip on the right hand side.
    -Disconnect the upper leftmost connector on the rear of the unit to allow access to the window relay. NB. The interior light will extinguish.
    Rear of Integration Relay
    By placing a link in the rear of the Integration Relay, the windows (and Power Seats and Sunroof where fitted) will work anytime.
    -Remove the Window Relay and keep in a safe place for future use.
    -Insert a link utilizing RED crimps and 10Amp cable into the upper connectors on the rear of the Integration Relay. These are the ones that seem horizontal when the relay is in its normal position.
    Integration Relay with link inserted
    Reassembly of Integration Relay and lower dash panel is the reverse order of removing.
    Enjoy
    Al Breeze
    Hope this helps dave0074.
    Thanks,
    ec24
    This guide is an extract from the LCOOL Website; 90 Series Technical Sub-Section.
    Welcome to Land Cruiser Owners On Line (LCOOL). 2012. Welcome to Land Cruiser Owners On Line (LCOOL). [ONLINE] Available at: http://www.lcool.org. [Accessed 27 October 2012]
    [b]Black 2007 Chrysler 300c 5.7L V8[/b]
    SOLD - 1997 Toyota Land Cruiser Prado GXL
