Fuse location for sunroof
  • Fuse location for sunroof
    I have a 1997 Prado SWB with a glass sunroof which stopped working for absolutely no reason, I am guessing the fuse, but I can't find anything either in the fuse box or the car manual that would lead to where the fuse is. Furthermore, I took all the small fused out but was unable to find any burnt ones :evil: Has any here experienced a similar problem?
    Any one here have an electric glass sunroof in their 90? Perhaps it was an option for this region and not in Australia? I have sunroofs on both my 90 series Prados :lol:
      Fuse location for sunroof.
      Try this Baz.On the lower dash just inside the drivers door there is a small plastic removeable panel.This is where optional acessories fuses are often located in side the vehicle ,not under the bonnet.PS Baz.I have never seen a sun roof on a prado in Australia so I am just having an educated guess.I cannot believe you never got a helpfull reply untill now, hope this works.
        For those wanting the sunroof look, try one of these.... :shock:
        Richard
        2011 GXL TD Auto Prado Silver
          Sunroof
          Hi Baz. Did you fix the sunroof?. If not there is a relay up near the motor check it out might be the trouble . If you need more info i have a toyota genuine manual that i can take some pics of the 5 pages on the sunroof and email them to you .Cheers Ian.
            Yes, I had the sunroof fixed at the dealer, I was to darn busy I forgot to ask them where the fuse was It should be fairly straight forward, I looked in both locations but could not find any busted fuses or one that is labeled sunroof!
            I have sunroofs on both my Prados
              Yes, I had the sunroof fixed at the dealer, I was so darn busy I forgot to ask them where the fuse was It should be fairly straight forward! I looked in both locations but could not find any busted fuses or one that is labeled sunroof!
