Electrial help needed
  • Electrial help needed
    HI guys im not any good with electrical work sadly so im reluctantly posting up with the hope that we might have a guru on here that maybe able to help me
    I have several items to wire up so if someone in sydney has some spare time ( god knows we dont have alot of that) to help me out i will be appreciative with libations (beer and lunch) all i really need is someone to guide me as i will do all the hard stuff my self
    Thanks guys
    Bigkev
    Bump
      Wow 150 views and not 1 person can even offer maybe some advice hmmm
        What advice are you after? Can you please provide some details
          Ive never wired up before and was looking for advive and help but im no longer bothing will look out side prado point
            I have lights to wire up at rear and side and as ive never wired up before was looking for some help ie guiding hand sadly your the only person thats actually bothered to post up so thanks kindly will be looking somewhere eles prado point doesnt offer alot of help to novice guys and isnt really catered towards helping newbies
              Kev,
              I am not an electrician, but wiring is fairly basic.
              Red wire to battery positive, black wire to negative battery.
              Light screwed or bolted to steel.
              If you google videos for wiring up spot lights etc you will get a mass of videos to watch....
              1999 Prado VX Grande White on Silver 3.4Ltr Auto
                As Below said However I am an electrician/technician, and its certainly not rocket science.
                Red is positive.. You can usually ground thru Chassis/brackets etc. Otherwise run a Black to a Ground (Negative).
                Fuse your feeds to your power source, then run them thru a switch. If you have a good ground or chassis mount, a single wire is all that's needed.
                You need to factor in a lot of people probably don't live in Sydney, and your OP was pretty scarce on info..
                For all anyone knew you wanted a twin dipthermal coupletec 3000 modulating valve or a chip it module wired up.. And we know no one will touch a Chip It module.. Especially on someone else's car.
                "Helpees" will understand me when i say: You also then get that issue where you turn up to help someone and half the gears missing, as they have no idea what they need or need to do. So it turns into a CF trying to help someone out. Not saying that nasty but the "helpees" have all been there were it turns to Sh!te before.
                If you'd posted it was just a few lights to be added, Id say you'd have more replies..
                Having a go and saying the site doesn't cater to newbies or offer help is way off the mark IMO.. (Today alone I've read a couple new posts where newbies are thankful the site and its posters have saved them money and time.)
                A quick search showed me:
                http://www.pradopoint.com.au/showthr...w-with-Photos-!!
                http://www.pradopoint.com.au/showthr...ase!&styleid=2
                http://www.pradopoint.com.au/showthr...ght=rear+light
                These links are a start for you.
                Piggy
                Water pistol pilot.
                  Guys i have everything i need i just needed someone with more knowledge than me but as ive said its ok will just look else where its a shame it takes me to get upset before anyone actually botheres but i gather its this way for guys behind there keyboards
                  And yes wiring up lights may not rocket science but to offer up a modicum of help either isnt that hard as well
                  Cheers guys appreciate you replys i will be leaving this forum
                  Take care
                  bigkev95series
                  Lurker
                    Thanks this has come to little to late IMO my commet was spot on
                      Sorry we couldn't all jump when whistled.
                      You know, we all have F-all to do with our lives other than wait for calls for help.
                      Thanks for coming, don't let the door..... etc.
                        Would you like me to close your username up for you?
                        It's funny that today (6 hours ago) you posted up the info that you were wanting to wire up lights. You've not said that before.
                        And Lo and behold the answers and links come rolling in within hours.
                        What this really comes down to is a lack of information in the original post. Meaning a lack of answers.
                        Best of luck out in the wide world of the web.
