Done 350,000 km. 95 series diesel 1KZ TE. Starter motor not engaging every time. Had just installed new battery. Checked i hadn't damaged any wiring or terminals. All OK. Car would start with head lights and spotlights on no problems. Only had trouble when no lights on. Before replacing/servicing starter motor I researched online and found that the starter relays sometimes can sometimes be the problem as many had replaced the starter motor and still had problems. New $90 starter relay from dealer and so far no problems on starting. Easy part to get at and change before the starter motor option.
starter motor problem
