Allzone fuse box
  • Allzone fuse box
    Like a lot of Pradopointers, my vehicle has a duel battery system which has numerous accessories running off it. It seemed that before each major trip I had to hurredly run another set of cables and inline fuse to the second battery so we would have enough power to run the necessities that we seemed to accumulate. Not being electrical in any way and rushing to get things done resulted in........ well I'll let the pictures do the talking.
    I knew that the above was a recipe for disaster so I decided I needed to do something about it. Thanks to a couple other threads on Pradopoint I decided to buy an Allzone fuse box to see if I could tidy things up a bit.
    This was my postive terminal before the Allzone (the blue stuff is something Toyota insist on applying during services)
    I attached the Allzone to the firewall near the wiper motor. It took some time to work out exactly where to place it and leave enough room for all the cables that would be added.
    Part way through the install.
    The finished product
    A close up of the Allzone with the cover on
    Not so much spaghetti now.
    The fuse box cost me $49 from the 12 Volt Shop and about $20 worth of cable and terminals. Everything seems to be running OK, so hopefully I have short circuted any potential problems and made things much simpler. The good thing about the Allzone is you can label each fuse and I have a bit of room left for expansion.
    Now all I need to do is to find some time to hit the road and test it out.
    Re: Allzone fuse box
    Hey Rianman,
    Nice write up. They are a great fuse block for a decent price. I have just installed 2 of them and would've been stuffed without them. I got them from Jamie's 12v shop on ebay.
    :shock: :shock: :shock: :shock: :shock:
    Crammy
    2008 GXL M6 D4D, Silver
    Build Up---> [url]http://www.pradopoint.com/viewtopic.php?t=2315[/url]
    [b]{[/b]ATS Ridepro/Bilstein Lift[b]}[/b] [b]{[/b]Dual Batteries with RanOx Battery Booster[b]}[/b] [b]{[/b]600w Projecta 240v Inverter[b]}[/b] [b]{[/b]Dunlop AT3's / MT MTZ's on Speedy Grande Rims[b]}[/b] [b]{[/b]ARB Deluxe Winch Bar[b]}[/b] [b]{[/b]IPF900XS Spotties - Converted to 50w 4300k HID[b]}[/b] [b]{[/b]35w H4-3 4300k HID Hi-Lo Conversion[b]}[/b] [b]{[/b]ARB Underbonnet Compressor[b]}[/b] [b]{[/b]GME TX3440[b]}[/b] [b]{[/b]T-Max 10,000lb winch[b]}[/b] [b]{[/b]Safari Snorkel[b]}[/b] [b]{[/b]Milford Cargo Barrier[b]}[/b] [b]{[/b]Rhino HD Roofies & AT1410 Roof Tray[b]}[/b] [b]{[/b]60L Waeco[b]}[/b]
    [img]http://www.gifs.net/Animation11/Transportation/Cars/4_wheel_drive.gif[/img]
      these fuse boxes are a good thing.
      easy to install all ya accesories.
      looks a tidy job
      [url=http://www.fuelly.com/driver/damonat/prado][img]http://www.fuelly.com/smallsig-metric/50578.png[/img][/url]
        I'll have to look into that myself, mine looks like Rainman's 'before' pic :?
        [url=http://www.4wdmonthly.com.au/forum/showthread.php?t=29022]My Prado[/url]
          Originally posted by Crammy
          Hey Rianman,
          Crammy
          crammy, why are you running 2x 6 packs?
          jamie does the bigger 12 in 1.
            Hey damonat,
            I have 2 six packs as one fuses a main battery supply and the other my auxiliary battery supply. I have set up a RanOx battery booster (DC-DC battery booster/3 stage charger) to maintain my dual battery system. They're a great unit and doing the job quite nicely.
            Ranox setup here ---> viewtopic.php?f=16&t=4117
            Crammy
            PS I think we need to make the new member registration harder to earn!! Man we're getting some tools come through!! :evil: :evil:
