Hi,
Managed to pick up a second hand central locking remote for our 2001 Prado. Followed the instructions on the (Toyota) manual included with our owner's manual to program in the new remote as below but tried for about 30 mins and couldn't get past step 5. No matter how many times I tried I couldn't get the indicators to flash at all (let alone 20 times :? ). Has anyone out there actually managed to do this?
Thanks,
fruitbat
"The following procedure details the steps to follow for the programming of additional remote transmitters. Use the first procedure if you have a functioning transmitter or the second procedure if you have no functioning transmitters.
With at least one functional transmitter
1. Ensure door is open
2. Remove key from ignition
3. Lock the doors using the transmitter
4. Unlock the doors using the transmitter
5. Within 20 seconds of unlocking, insert key into the ignition cylinder and turn key from the "ACC position to the "ON" position 20 times - leaving the key in the "OFF" position after the 20th turn
6. The vehicle's indicators will flash 20 times to indicate successful entry
7. On the 20th flash of the indicators, press the button once on each transmitter
8. Once finished, turn the ignition key to the "ON" position to lock in and exit from the programming mode"
Thanks,
fruitbat
