Guys, I have a UK spec 90 swb. The model here is the GX. On the VX you got a dashboard mounted pod with extra meters in. Inclinometer etc. I have managed to get a set of these from a scrapper and thought that, in the usual Toyota style, the wiring loom would be there. I have the dash out and don't seem to be able to find any plug socket. It came with a lead about 300mm long to go through the top of the dash. I was wondering if this is a more common fitment in Australia and if you had and knowledge of where it connects up. I imagine that not everything like external temp sensors might be there, but power, speedo connection etc might be. There does seem to be quite a few wires in the plug which I am surprised at seeing as how most of the clever bits seem to be inside the housing. I wondered if there might be an additional lead to connect the flying lead to a point somewhere else behind the dash.
C
C
