90 Series Optional Alarm Upgrade
  • 90 Series Optional Alarm Upgrade
    So I'm trying to find an upgrade kit to suit the VZJ95 GXL. I've got the genuine accessory number for the kit, but of course Toyota don't supply them any more!
    It was a kit made by Toyota Australia also, so google provides literally 1 result.
    If you've got the optional alarm you should potentially get either a soft chirp or a quick horn beep when you lock and unlock the car. It'll also go bananas if you open a door without the remote when it's armed. I think it also has an LED on the dash, but who needs that anyway!
    The alarm upgrade kit : PZQ71-60065 - It only works with the PZQ71-60073 central locking module(little black box behind p/side kick panel), which was optional for the RV, RV6, and GXL 90s I believe.
    Hopefully someone on here has that kit in their Prado and can help me out with some part numbers and wiring connector locations.
    The alarm siren should sit under the bonnet up near the cruise control and ABS/brake booster apparently.
    It'll connect up to a 3 pin connector there, plus wiring must go over towards the battery where there's a connector as well.
    I've gotten to the point of finding the two wires for the bonnet pin switch, can make the car not want to lock if you short them together.
    I've got a feeling that you'd need to add/remove a few pins on the central locking module as well to 'tell' it that it's now an alarm.
    Then you can do the programming that is explained in the "Prado Remote Central Locking and Optional Alarm" manual in my glovebox.
    If anyone has any information that can help me more than Dr helpful Toyota dealerships I'd be really appreciative! Would be perfect if someone has kept the blue accessory box in their shed with the fitting instructions still!
