Hello, I am new here, and my english is not good. I am driving my old prado 90 series. My air con dial and the other dial doesnt light up at night, and my multi info doesnt show anything anymore. Can you guys help what is the problem?
Is it the fuse?
G'day mate. first off, not the fuse sorry... the dashboard, clock, hvac and multi info lighting all run on the same circuit, so if it was fuse... you'd have no instrument lighting at all. More often than not, it's simply the bulbs have burnt out over time. But could also be a wiring issue behind the centre section of the dashboard. I'd be checking the bulbs first though.
ok thank you ya..Originally posted by RanJ View PostG'day mate. first off, not the fuse sorry... the dashboard, clock, hvac and multi info lighting all run on the same circuit, so if it was fuse... you'd have no instrument lighting at all. More often than not, it's simply the bulbs have burnt out over time. But could also be a wiring issue behind the centre section of the dashboard. I'd be checking the bulbs first though.
