Location of power antennae relay
  • Location of power antennae relay
    Does anyone know where this relay is located? I've searched the car, looked through Gregory's but can't see where it's located.
    The heavy rain must have killed something in the antenna up/down circuitry
    Just to lower right of radio, set back behind the dash. Module stands upright and faces perpendicular to the front of the car.
      That pointed me in the general direction, thanks. The location of the relay in my car was under the radio on the left.
      The limit circuits in the antenna itself wasn't working causing the relay to ignore all up/down requests from the radio or manual switches. I've wired the relay to work manually off the up/down switches instead of changing the antenna which was expensive. Just got to make sure that the buttons are not pressed continuously at the antenna limits in order not to strip the gears).
        hkmus that's a pretty good workaround, especially if you don't use the radio that much. All I use my radio for is a bluetooth player these days
