Hello everyone
I have a manual 1997 2700 4cyl Prado. Recently the battery was replaced with a high crank capacity battery. The battery is the correct size per specifications for the car.
The first time this issue occurred, I turned the key and all I heard was a click, the same click you hear when you have a flat battery. I turned the key again and the starter motor instantly spun up at full speed. It was as if someone had instantly replaced a dead battery with a new one.
This occurred twice more on different days over a few weeks. Until yesterday when for three consecutive attempts, all I got was the click. Then fourth try it started.
Drove to the shops, but this time starting there was a click a short laboured attempt to spin over the engine and then stopped. Then once again the next attempted started the engine.
All this behaviour makes me think somehow the battery is defective. How it can show this nothing then full charge I don't know. The terminals are clean and secure and the battery which cost over $200 is only a few months old.
Any thought from your experience will be appreciated.
