I have two gutter mounted roof bars. I plan on building a box to go on them and I have already mounted small worklights to light up the ground to the sides. I have not wired the lights yet because Iīm not sure whatīs the best way to route wires up there and to get them to the outside.
I want to lay some wiring up there for future use. Worklights for the back and sides, forward facing spotlights and/or a search light and solar-cells. So thats probably 5 12V+ wires and a common ground, and the wires for the spotties and search light will need to support a 100W bulb.
Should I drill the B-pillar and have the loom come out between the doors and run it up the roof bars leg, or should I drill a hole in the roof and pull my wiring thru one of these (see image below) and seal it with plenty of silicone? I will have a junction box in the roof box for the common ground wire and more.
How did you run your wiring to the roof rack? Any hints or tips? Is there any "official" route for roofwiring in a Prado, inside pillars or behind interior panels. Iīm quite capable og connecting everything but I donīt want to start drilling my roof if there is a better way. The rack will not go further back than 1/3 of the cargo area windows and no further front than mid front doors.
