Replacement Bullbar Parker/Indicator Combo Light
  • Replacement Bullbar Parker/Indicator Combo Light
    So ... I have a TJM steel Bullbar and it has the recessed Parker/Indicator Combination Lights. I have been upgrading some of the globes at the front end with LED / SMD globes and when I came to remove the covers on these lights I found that the seals were all but Rat S*%# and the lense on the passanger side light had a hole in it (obvious stone strike). Now be buggered if I can find anyone that stocks anything even close to a match. The closest I have found so far is Part No. 9006-00 at http://www.britaxae.com.au/products.php ... 121&page=1
    Can anyone recommend any suppiers of vehicle lights that might stock what I am chasing? For those that aren't sure, it is a rectangular fixture with ~2/3 indicator and ~1/3 Parker (the lense is one piece, clear over the parker and amber over the indicator). As seen on the TJM Steel Deluxe Bar here http://www.tjm.com.au/Default.aspx?tabid=59 :?:
    [b]2000 Prado RV6[/b] ~ TJM Type 15 Steel Bullbar ~ Uniden 400SX-RM & GME4702 Ant ~ Front Tow/Recovery Hooks ~ ARB Recovery Kit ~ ARB CKMP12 Air Compressor ~ DIY Rear Door Trim & Table ~ Extended Diff Breathers ~ Safari Snorkel ~ Wireless Reverse Camera ~ Iron Ox Full Length Roof Rack ~ Looong Wish List ...
    Re: Replacement Bullbar Parker/Indicator Combo Light
    UPDATE:
    Just called my local TJM Dealer (should have done that first ... right?) and TJM only have 2 sets of lights across their entire range of bars (handy piece of info right there). One is a flat out inidcator and the other an indicator/parker combo (the one I'm after) so the search was made that much easier. Replacement cost? ... $60.50 a pair, so not as bad as I thought ... for a genuine item.
    So disregard my request all! ops:
      got a picture and part number.
      TJM wouldn't make the light, so does it have other details on the light.
        I'm replacing the parker/blinker in my ARB bar with these. They're on backorder, just waiting for them to arrive.
        Page 83
        http://led-catalogue.ledautolamps.com/O ... E/ledtech/
