Dear Pradopoint Oracle,
Ok, so leaving things to the last minute as usual, it was pointed out to me that the reverse lights on the Prado don't work. Typically the pink slip is due to be done tomorrow and I can't for the life of me figure out why they aren't working.
I pulled every fuse under the dash & bonnet, pull the tail lights to check globes (good) & checked for power with a test pen, nothing. The earth is fine, all other tail lights work fine. Pulled all the plugs around the gearbox and sprayed a bit of contact cleaner. All connections along the top of the gearbox are pretty well sealed as well.
Is there a switch wire or something under the centre console?
Please help, as Im stumped
