Guys, i was thinking, are any of you running roof mounted spotties? i was thinking, instead of mounting a bullbar, I thought id install a roof rack, and mount the spotlights on the roof. Now, I've got a couple of ideas but i'm kinda stumped as far as wiring goes. How'd you run it? where did you pass the wiring out to the roof? any tips?
Also, I wanna install a power inverter, but don't know how or where. Most automotive inverters ive seen have the lighter outlet connector, but i wanna make it a permanent install. How did you guys do the install? permanent? with the lighter socket?
thanks in advance!
thanks in advance!
