cigarette light wires ?
  • cigarette light wires ?
    hi guys I dont have a multimeter at home was just wondering if any one can tell me which is the power wire . I am talking about the lighter on the right hand side not the accesoriy port on the left side. now there is a plug with two wires going into it and a single wire plug on mine
    2002 90 series rv6 manualy with arb winch bar
    Re: cigarette light wires ?
    Pics might help here Wazza1978 :idea: Have you tried the search function :?: My guess would be that the centre pin of the cig lighter would be positive and the outer part of it negative but I would not attempt this without confirming with a test light/multimeter. Difficult to comment without knowing exactly what it is.
    Johnsy
    [url=http://www.fuelly.com/driver/johnsy/prado][img]http://www.fuelly.com/smallsig-metric/47401.png[/img][/url]
      Johnsy
      you are correct, no worry.
      that is the universal design for cigarette lighter in cars. if they change the order of the negative and positive wires, other devices which are used with cigarette lighter would be destroyed.
      I really don't know if there is ONLY ONE WIRE connected to your cig lighter or TWO WIREs.
      If in case it is TWO WIREs, it should follow the rule above.
      If in case there is ONLY ONE WIRE connected to this cig lighter, it should be positive, and your cig lighter should be screwed or snap on a metal surface in your dashboard which already provides negative source all around the car, so it does not need another negative wire.
      BTW, one photo will talk better.
      cheers,
      Vuong
      [b]1997 RV6 3.4L Petrol, manual.[/b]
      [b]FUEL: 15L/100km[/b]
      [b]- Mods done:[/b] TJM roofrack/2nd battery/Power windows-mirrors/LED mirrors-signals-Eagle eyes-Angel eyes-all around/2x12.3" sunvisor LCD/Automatic roll up-down windows/Chrome cover all around/6.1" Kenwood DVD w 180Gb HDD/4 amplifiers/4x12" subwoofers/Air compressor/Weaco CF-32/4 oval x HID front light/Hot shower/Water pump/Bike rack
      [b]- Waiting list:[/b] vertical Lamborghini door/UHF/2x9"DVD headrest/Pioneer components/19" DVD roof flip down/12k lbs winch/XXX...
        its all good will bring home my test light from work
          Its a good chance that the plug with two wires will be for the illumination light and the single wire (doesn't entirely make sense - should be 2) would be the actual cigarette socket. Another indication to which is which will be the guage of the wires - smaller wires will be illumination and larger will be power...
          As for testing them with a multimeter? Connect one end of the meter to body earth and then touch the other to one of the wires. A 12Vdc reading indicates power/supply side and a 0Vdc reading indications body earth...
            Not being too critcal Wazza....you can pickup a multimeter these days for $9.95 to through in your kit. Very handy for this type of work & also trying to diagnose other electrical issues...
            http://www.jaycar.com.au/productView.asp?ID=QM1500
            Even if your not too familiar with them, the person that stops to help you maybe. :shock: :lol:
            Richard
            2011 GXL TD Auto Prado Silver
              no its all good thanks I have a multi meter too. Just didnt have it on me at the time was at work
